Microsoft word labels will not print from rear tray - possible solution
LouGuay67
If you used Mail Merge, on the Label Options screen, there is a printer menu in the top left-hand corner. Select rear tray here.  Otherwise, the labels will print to the default feed (cassette).  Hope this helps
1 REPLY 1
yadirmanns
Open the printer properties or settings and ensure the default paper source is set to the rear tray.
