02-25-2017 10:20 AM
My MX922 won't print black and white. I am running apple OS 10.12.3
When printing, I check the box for black and white but it still prints in color
03-10-2017 01:07 PM
Hello.
To print in Black and White, the Grayscale option has to be enabled.
Get to the "Quality and Media" section of the print menu and check the "Grayscale" box. This should allow your color item to print in black and white.
03-12-2017 07:39 AM
03-13-2017 06:59 AM
Hi kwd323,
Please try opening Safari in 32 bit mode. To do this, close Safari and then select the Go menu from Finder and click on Application. Click on Safari once and then click on File and Get Info. Select Open in 32 bit mode and then open Safari. Quality & Media should be an option now.
03-13-2017 08:52 AM
I mostly use firefox. Is there a way to print black and white in firefox?
03-13-2017 12:23 PM
Hi kwd323,
You can try those same steps with Firefox as well. Using Firefox in 32 bit mode should allow you to access the Quality & Media drop down box.
03-15-2017 06:59 AM
Changed firefox to 32 bit but still do not see 'quality and media' or grayscale on print menu
did I miss something?
03-15-2017 11:31 AM
Hello.
Check to see if there is a way to expand the print dialog menu in your program. This may allow you to access the options for the printer.
If you continue to have difficulties, please contact our support group using the "Contact Us" link below for additional assistance.
03-15-2017 11:41 AM
Already tried all of the drop down menus on the print menus with no success finding greyscale
I've used the same printer in windows without having to make obscure modifications to print basic functions like black and white printing
Is there a canon printer model that is fully compatiblle with apple?
