MX922 setup problem
CJB
Trying to set up my new MX922.  When I turn it on I get a message “Support code 5101.  Remove the protective material if it is attached to the holder and turn off power and back on.”  There is a diagram showing the top open and a bit at the side.  I have removed all the protective plastic and tape I can find.  I have turned the printer off and on several times but get the same message.  Pressing the Menu button does not change it.  What should I do now?  Is there a place where I could have missed protective material, or a way to get past this message?  adTHANKSvance!
1 REPLY 1
Kerryanne
Not sure if you figured it out yet .  But  that orange  tab  comes out of that spot. I ended up chatting with  support;
Friends and Family
