10-04-2013 05:00 PM
I am trying to scan using my MX922 printer. I am getting a message: "set the pc to start scanning." Can't find what this means.
05-17-2017 01:21 PM
Hi therealjohargis,
Are you using your PIXMA MG5522 with a USB cable or are you using it wirelessly?
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
http://Canon.us/ContactLI
07-03-2017 10:49 AM
I'm using Windows 10. The scanning is the scanning software that was with the Cannon MG7720
07-03-2017 10:50 AM
we are wireless
07-10-2017 11:41 PM
how do we set the PC to start scanning
07-11-2017 06:36 AM
Hi ronjudyva,
The scanning software for your PIXMA MG7720 is the IJ Scan Utility. This software gets installed during the driver installation on your computer.
To use the IJ Scan Utility, please view the following page from the On Line Manual of your PIXMA MG7720:
http://ugp01.c-ij.com/ij/webmanual/ScanUtility/W/MG7700%20series/1.1/EN/SU/Top.html
If you require further assistancce, please contact Canon's Contact Center using the following link:
12-13-2017 02:01 PM
THIS WORKED!!!! i never noticed the buttons ON the printer (scanner) THANK YOU!
12-13-2017 02:17 PM - edited 06-13-2018 12:19 PM
TRY THIS IT WORKED FOR ME!!! They, (Canon) needs to change the wording on this. you're not actually "setting" anything on your computer you need to select something ON THE SCANNER itself. After pressing SCAN There are 2 buttons on the bottom. on the left it says save/ forward on the right it says scan settings.
Choose the Save/Forward option. Then choose OK. Next, it should give you the option for your wireless pc connection. On mine, it lists Local (USB) and ALSO my account which is logged in on my computer "Anns Laptop "
when I chose "Anns laptop" that did the trick. That worked.
If only Local (USB) appears, try either turning the printer off and back on again, or possibly doing the same with your router or modem...anything that will get the printer looking for that wireless connection again. Why the folks at canon can't tell you where that screen is is beyond me.
01-31-2018 11:19 AM
I am getting this meessage as well and am on a surfacer running windows 10. can anyone help?
01-31-2018 12:15 PM
did you try what i posted?
its a setting on your printer i believe.
05-03-2018 01:44 PM
dmichlin88,
If your Surface device is ru nning a full version of Windows 10, make sure that the latest drivers are installed. Visit www.usa.canon.com to download the latest drivers.
If you continue to have difficulties, find more help at Contact Us.
