11-05-2016 01:04 PM
My Pixma MX922, now more than 2 years old has very poor print quaity. I've run alignments and cleanings but it still prints with very wavy lines (vertical and horizontal) and characters have faint shadows like a double impression. How can I fix?
Many thanks for any help,
07-23-2017 02:14 PM
how to fix wavy print having very little luck on trying to fix I will call as this online idea is just a idea it does not work there is nothing at all to help me fix my piece of equipment in fact I have two
09-14-2017 04:10 PM
Have you found a solution to this problem yet? If possible, please can you send a high resolution scan of the black nozzle check pattern. It may give a clue as to what the problem is.
Kind regards
chris
12-01-2020 03:10 PM
The only thing that seems to work for me is printing using the "High Resolution Paper" selection instead of "Standard". The printing takes longer and uses more ink, but the wavy black print problem is gone
10-23-2022 11:38 PM
I tried LBD's suggestion above (the clipped corner paper) and it worked!
