11-21-2022 02:17 PM
Have done one deep cleaning and problem still exsist.
11-21-2022 04:11 PM - edited 11-21-2022 04:13 PM
Old ink, a worn out or partially clogged printhead (due to infrequent use) can all cause the problems you are describing. Have you performed a printhead alignment?
Also, a dirty timing (encoder) strip is something else you can look at.
Have you checked this:
Canon Knowledge Base - Clean the timing (encoder) strip - MX922
11-21-2022 04:17 PM
Thanks I’ll try that
