MX922 Wont power up
AlanC
My mx922 has been a great pinter until now. I went to print something and found that the power was off. I checked that the power cord was plugged in both ends and there was power to the outlet I was using. When Ipress the power button nothing happens. The manual says to leave it for 3 mins and try again. That did not work and manual says contact service department.
Does anyone have any ideas. Thanks in advance.
7 REPLIES 7
Michael
Hello,
Try using a different power source or power outlet to see if this will resolve your issue.
If the unit still remains off, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
my mx922 is having this same issue. i printed document over wifi, loaded another sheet of heavy paper went back to pc to print and the printer was offline.went over to printer it was off checked cord, checked outlet for power , moved to different outlet, unplugged for 30 seconds and help power button like i seen in another forum. none of these have helped me at all any help is appreciated. thanks in advance
Ziingster
I took out the power supply and wiggled the two black fuses till it worked....You may want to get a new power supply. I don't recommend playing around with live electronics. I just happen to be a technician.
I repaired my MX722 by removing the power supply and wiggling the fuzes..The whole side of the printer must be removed to find the fuzes...not recommended for most folks but I am a technician...do you sell new power supplies?
I replaced the power supply with a new one. Still did not work. Assumed it was the logic board so took it to bestbuy for recycle. Very dissapointed as it was as new, not used very much.
I have tried all the suggestions I have seen here including I bought a new power supply and still won't power on at all. Any other thoughts out there or is it time to ditch the printer?? It's only a few months old so I'm very disappointed in seeing so many problems like mine out ther. Has Canon address the real issue??? Your thoughts
Hi silvervet2,
Because your PIXMA MX922 was purchased less than a year ago, it is in warranty.
Please contact our support group for your service options using the following link:
http://Canon.us/ContactLI
