07-20-2014 03:45 PM
My MX 922 leaves a thin vertical line on copies when the original is fed through the upper feed. No line on documents sent from PC or documents copied from the scanner glass. I've performed all the listed cleaning steps. TIA
07-30-2014 07:40 AM - edited 07-30-2014 07:40 AM
Hi smiley47,
The lines on copies that you are experiencing is a result of the scan glass being dirty or scratched. The scan glass that the printer uses when scanning from the ADF is located to the left of the larger glass area (platen) when you open the cover. It is the smaller glass strip on the left hand side of the unit.
Spray some glass cleaner on a paper towel and then clean the smaller glass area. Once cleaned, try scanning from the ADF again.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
04-17-2020 05:39 PM
This page had the right instructions for fixing my problem. So that's good.
At the bottom of the page, there is a suggestion to click the "Accept as Solution" button if the solution was good. But there is no such button. There is a "Kudos" button, though. You shoud change the text to match what is on the button.
08-15-2020 04:20 PM
This did not fix the problem with the vertical stripe on my 922. Cleaning everything and replacing the ink cartridge did not help. I have a wide blue line when printing in color. I can hear the ink cartridge carrier printing, even when the scanned document is blank. This is the first day I've used the document feeder for my new computer, and I have not had this problem before using other computers. Please send a solution.
08-21-2020 04:26 PM
Hello, kateuscher,
We would be happy to assist you with your vertical lines in the copies. The issue that you are describing looks like it is a different problem with the scanner. The issue that this one addresses would cause thin black lines. To further assist with the issue, we would need some additional information.
Once we have that additional information, we can assist further.
08-21-2020 05:41 PM
I fixed my problem by cleaning the scanner window in the area shown in the diagram at the top of this topic. Used "invisible Glass" cleaner.
02-15-2021 02:06 PM
Hopefully this will still find a recipient. I've tried to clean my glass, but still have a blue line.
To answer the questions below:
1. No line when i scan with the glass
2. Yes, the line is a light gray when on Grayscale
3. Yes, always in the same place. About an inch from the right edge of the paper.
Maybe it goes without saying, but the same line appears whether i am copying or scanning from the document feeder
02-16-2021
12:53 PM
10:35 AM
Hi heffdad,
There is a mark on the scan glass that is transferring to your copy/scan.
Please view the image in this thread above for the location of the portion of the scan glass to be cleaned.
Even the smallest mark can cause this to occur.
If you have cleaned the glass and the line persists, there may be a scratch on the glass causing this. In this case, your PIXMA MX922 would require service.
You are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
To help you get up and running quickly, we also offer free standard shipping (if the order is completed by 12:30 PM ET). If you would like to take part in this option, please call our Sales Department at (866) 443-8002 weekdays and Saturdays after 11 AM ET (8 AM PT). Let them know you have been working with technical support and the Canon Upgrade Program was offered.
09-13-2022 11:34 PM
Yes, cleaning the glass surface worked perfectly to eliminate the vertical lines!
