04-25-2020
02:20 PM
02:28 PM
Printer is defaulting to upper paper tray when printing docs. How do I change this?
04-25-2020 02:24 PM
05-06-2020 03:42 PM
Hi Richard1188,
What version of Windows is installed on your computer? If you are using a Mac, what version of OS X is installed?
06-09-2021 06:27 PM
I am using Windows 10. This problem only started recently and I am wondering if some Microsoft update that came through caused this problem for me.
06-09-2021 06:48 PM
Where can I find a response to my inquiry since it appears to have been asked before?
06-11-2021 04:22 PM
Hi emjjjeeeorg,
You can set the source of the paper by following these steps:
1. On your computer, please press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run box that appears, type CONTROL and click OK.
3. In Control Panel, click on View devices and printers.
4. Right click the Canon printer that you own and left click on Printing Preferences.
5. In the next window, in the lower right side, you can select the source from where the paper is fed from the Paper Source drop down box.
6. Click Apply and then OK.
03-29-2023 06:55 PM
In two years am I the only one who has his problem on a MacBook Pro. Well, I do and I have had it before, but I found a solution in the past on Settings, but I cannot find anything to change the print tray..any help?
