MX922 Printer - copy and scan function do not work
bullwinkle
Have had MX922 Printer for about 3 yrs; now I can print from computer but the copy and scan function only works with a large black vertical box (about 3" wide) printed on the page
Have gone through all troubleshooting tips - cleaning and deep cleaning print heads, alignment OK, cleaned the timing strip, turned off and unplugged printer for 5 mins before turning on again multiple times.  Also uninstalled and re-installed printer driver.
Get printer code error 5011 which was found with instructions to turn off, unplug printer, etc.
Get scanner code error 2,250,4   - cannot find a reference list for scanner code errors
Anyone have any other ideas, cannot really afford to buy another printer right now.
Thanks
1 REPLY 1
Patrick
Hi bullwinkle,
When you scan or copy, are you using the docoument feeder or placing the original face down on the scan glass?
Does the 5011 error clear?  If it does not, your PIXMA MX922 would require service.  You are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take part in this option, please call our Sales Department at (866) 443-8002 Monady throuigh Saturday, 9am to 9pm. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
