08-09-2014 06:23 PM
MX920 prints multiple copies even though print menu is set to 1 copy. How do I troubleshoot this?
03-27-2017 10:25 AM
I'm also having these same problems with MX470 printer!
Very annoying!!!
11-14-2017 01:38 PM - edited 11-14-2017 01:38 PM
Im having same issue with windows 10. Printing multiple copies. I am printing over wireless MB2100
01-17-2018 07:12 AM
Hi nondrus,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
01-30-2018 04:14 PM
Spoke wit Canon tech support and this worked for me. I have a Maxify MB2720 and the printer port being used was WSD. I disabled WSD and added a static IP address. On your computer, go to control panel, devices and printers, right click on your printer icon, and select properties. In the properties box there should be a tab for "ports". Click ports and if WSD is selected this is what I did. Go to your printer, Lan settings, and disable WSD and determine which IP address is being used, usually 192.168.1.xxx. Go back to your computer, control panel, devices and printers, right click on your printer icon, properties, ports, add port, in the menu choose TCP/IP and next, a dialog box open, select ok, then type in the IP address in the box, both boxes will populate. Select ok, click yes if prompted. Click apply and OK. You will have to do this on each divice connected to your printer. Different operating systems may have different tabs but this is the jist. If you are using windows 10 make sure to go through control panel and not just settings. Hope this helps.
01-31-2020 11:46 AM
I am having the same problem. When resetting my printer, I found the LAN it was using was from my Roku device, not my wireless network. I reset the LAN to my network, and it seems to have fixed the problem. I also reset it to factory settings.
