07-21-2018 01:02 AM
07-23-2018 11:53 PM
07-23-2018 11:18 AM
Hi GerryPeters,
Please try reconnecting your PIXMA MX922 to your wireless network:
1. Turn your PIXMA MX922 on.
2. Press the MENU button on your PIXMA MX922.
3. Use the arrow buttons to select WLAN Setup and press OK.
4. Press the STOP button (to select Other setup options).
5. Select Standard setup and press OK.
6. Select your wireless network name from the list that appears and press OK.
7. Press OK to access the on screen keyboard and enter in your wireless network password. Please note that this password is case sensitive and if it is entered incorrectly, your PIXMA MX922 will not connect to your network. To switch between upper case letters, lower case letters and special characters, please use the middle function button below the LCD of your PIXMA MX922.
8. Press the left function button under the word "Done" once the password is entered.
9. Press the left function button under the word "End Setup".
10. Press OK once your PIXMA MX922 is connected to your wireless network.
Once reconnected, please attempt to print.
07-23-2018 08:11 PM
I even reset my printer.... nothing.
the drivers install and still nothing! I tried a windows and a Mac.... again nothing! )o:
07-23-2018 11:53 PM
08-03-2018 12:47 PM
I again lost the MX920 printer in my network. I did the exact same procedure above and now it's back. I've never had anything like this happen. I've had the MX920 and the MX410 for well over a year, maybe 2 years and this is a first for this to happen 2x in a row in a short period of time.
I assume something is corrupted in WIN 10, so I went ahead and removed all the printers from Control panel/ Devices and Printers, except the MX920 and the MS print to PDF. I then reinstalled the MX410 printer. I removed Fax and one other MS printer something like XML, which I have no idea what it is, just something WIN 10 installed I suppose.
So I'll see if any of this helps. Any other suggestions would be welcome.
11-13-2019 12:38 PM
I was having a hard time getting the MX 922 I have (same difference as the MX 920) to shwo up by using the standard windows "add a printer" dialog. No matter how I did it I ended up with a non responding printer.
Here is how I fixed it.
I was using the WPS which should have worked. I decided to add the printer manually to my network. Not sure if this was the solution but certainly the WPS part was not working.
The most likely fix was to use the driver that Canon on the website rather than the windows setup.
Here is the link
Here is the name of the driver
mp68-win-mx920-1_01-ea32_2.exe
It appears to do some registering that you do not see when the WIndows Add Printer option is used.
Yes it is an old driver but it does work.
I used the same technique for another computer. Both fine.
10-08-2020 12:45 PM
I've had a MX920 for a few years, and it often needs a wake up, OK.
But recently though it's printing fine, I also use an Avery template to print mini labels.
This past week though I've had mixed result. it copies but now besides saying it's Off Line which it isn’t, as it connected by USB. I tried all the usual disconnecting, the USB etc to no avail
So besides doing a complete reinstall I don't see any other option.
Any thoughts would be appreciated.
Regards from Blighty
Ben Cowell
10-08-2020 11:42 PM
I have 3 computers in my network Win 10 computer #1 which has the printer, a Win 10 computer #2 and an XP computer. I use these computers to print every day. After years of dealing with this, I found the best approach is to not use my XP computer using remote desktop to my Win 10 computer #2 to print. That works most of the time but seems to confuse the network printer and it goes offline.
Still even with doing that I still lose the printer maybe once a week while using my Win 10 computer #2 to print. I then simply reboot the Win 10 computer #2 and it then works again. My ATT modem/router won't let me give the printer a static IP address.
10-09-2020 08:06 AM
Hi Gerry Thanks for your comment, rebooting, recoonecting etc doen't work, about to to reinstall the application, no other option. 'It must work' he muses, I'll soon find out. Ben
