01-31-2015 09:01 AM
MP620B makes squeaking noise before & after printing - does it need lubrication?
02-12-2015 12:32 AM
Hi joemehling,
Since the squeaking noise continues, we recommend having the unit looked at by a service facility to determine the exact cause of the noise; please call or email us at one of the methods on the Contact Us page for servicing options available to you.
02-04-2015 04:52 AM
Hi joemehling,
We do not recommend lubricating the printer, as this could do damage to the unit. You can try performing a roller cleaning to see if this will help. To do this, please follow the steps located here.
If you still experience the same squeaking noise, the printer may require servicing; please call or email us at one of the methods on the Contact Us page for further assistance.
02-08-2015 10:45 AM
The squeaking continues, after cleaning roller heads. Apparently the noise is not caused by the rollers. The machine performs normally during actual printing; just before & just after printing is when the squeaking happens.
Any ideas?
Thanks for your help.
02-12-2015 12:32 AM
Hi joemehling,
