MP495 has random cat hairs or something inside?
trifles
I've tried the usual cleaning utilities but nothing has helped, including the Q-tip suggestion related to Bottom Plate Cleaning (and the hair marks are on the printed side, not the back of the paper). There must be a way to find and remove whatever is causing this - see image. Help?
3 REPLIES 3
The missing lines in the test pattern would appear to indicate a partial clog of the printhead.  This might cause smearing, etc.  I'd start with a cleaning operation.
This is helpful - thank you! I'll run that and report back to the forum....
Well - things seem to have gotten worse. Ugh. I feel like there must be an easy solution....
