09-07-2014 11:31 PM
I bought my PIXMA MG 8220 All-In-One Color Inkjet Printer on November 25, 2012 from B&H. It worked great during the last one and half years. But it can not work recently. After pushing the power button, there are continuous "click, click..." sound for about several minutes. Then I got an error message "5000". There is also a flashing orange triangle sign on the panel. I tried several times but the issue remains. I will tried to clean up the time strip, but it did not help. Could someone please help to resolve this problem? Thanks a lot!
09-24-2014 02:30 PM
Hi wnwang,
The 5000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 5000 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the 5000 error, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
11-24-2015 11:09 AM
11-29-2015 11:46 AM
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
