08-06-2020 08:48 PM
The CarePAK plus info page says that it covers normal wear and tear.
What constitutes "Normal wear and tear"?
Does it cover printer failures like Error Code 5B00, which seems to be the most common cause of early death.
The G7020 I just bought has a maximum duty cycle rating of 5000 pages/month. Is anything less than this considered "normal"?
My anticipated usage is 1000-1200 pages/month on average.
08-10-2020 01:31 PM
08-10-2020 12:35 PM
*Bump*
Still looking for an answer.
08-10-2020 01:31 PM
Hi PHL1365,
This issue would be covered.
10-17-2020 08:22 AM
I appreciate this clarification, as I too had this question.
I recently purchased the Canon Pixma G7020 MegaTank, the same printer as the OP. However, upon revisiting the Canon website a week or so later with the intent to purchase a CarePAK protection plan, it appears that the 2 and 4-year protection plans are no longer available. All I see is an option for "No Plan".
This was not the case just a week ago when I purchased the printer, and had I known the protection plans would be discontinued for the G7020 I would not have purchased it. I see that the plans ARE still available for the other MegaTank models, including the G6020.
Is the lack of any available CarePAK plan selection on the website merely a glitch, or are they in fact no longer offered for the G7020?
11-08-2020 03:00 PM
Looks like it is still there, but only the 2 and 4 yr options.
Go to this link:
https://shop.usa.canon.com/shop/en/catalog/service-plans
Enter G7020 in the search field and it comes up with the options.
Alternatively, you could just call on the phone and they could probably get you hooked up.
Finally, you can purchase through bhphoto.com or maybe some other retailer.
