05-31-2022 08:10 AM
My cannon MG7520 printer will turn on and start to go through its normal routine, but then unexpectedly turns off. The power cord has been checked, unplugged and replugged. Same result. Looking for other solutions if there are any.
06-03-2022 06:14 PM
Your satisfaction is important to us, and we apologize for any inconvenience you may be experiencing. A firmware update is available to fully resolve this issue. You can download the firmware update and find easy installation instructions at canon.us/power.
06-03-2022 08:36 AM
Here too, but this seems to have fixed it for now:
06-03-2022 04:52 PM - edited 06-03-2022 04:54 PM
My friend had this exact same problem. It is entirely Canon's problem. They recently pushed a software update that basically turns the printer off when it connects to the internet. To fix it you'll need to block it from connecting to the internet and then it should be fine. Most routers have this kind of functionality build in via some sort of parental controls. You'll want to block WAN (internet) access, but not LAN (intranet) access, so you can still print while on your home network. It's the issue of planned obsolescence, since Canon wants you to buy a new printer and (probably) more expensive ink.
06-03-2022 06:05 PM
The workaround is (others suggested and worked for me)
turn off your home wifi/internet
your printer should turn on
Go to setup
turn off LAN
turn your home internet and wifi back on
you’ll have to hook your printer up to your computer to print
06-03-2022 06:14 PM
06-03-2022 06:30 PM
Same issue. Why hasn't Canon been on the ball with this? Please offer a straightforward solution for non-techies, please -- under deadline to print and scan documents for work. Bummer.
06-03-2022 06:55 PM
06-03-2022 06:57 PM
this worked for me. Easy to do. Good luck
SOLUTION: After a 1:57 hold time with Canon customer service.... I have the solution! (and that was 2 hours, not 2 minutes) If this is happening to you it is very easily fixed. [Removed per forum guidelines] Although I wish I could sell it to make up for my 2 + hours of time. Here is what you need to do to fix it:
Completely unplug your router and then turn on your printer (it won't stay on if your router is because of a linking problem with the router, that we are going to fix.) So this is the step-by-step for the MG6620 and probably those models with similar menus, but whatever model you have just try to get to your DNS Server Setup. That is where the setting is that needs manually changed. So for the MG6620:
On the menu swipe to Setup, then find Web Service Setup then DNS Server Setup. Select Manual. Press each set of numbers and change them all to 000 except the last set. That needs to be 001. So your DNS will look like this: 000.000.000.001 Click OK, then click No.
That's it. You should be good to print.
You are welcome! Too bad someone at Canon doesn't just post this somewhere. Would've save a lot of people a lot of headaches, I'm sure.
06-03-2022 09:59 PM
The problem has been solved. Canon just posted a new firmware update for Windows and MacOS users. It can be found at the link below. You need a USB cable. Plus internet has to be down when installing the driver. Took me about 10 min in total. Works like a charm.
06-03-2022 10:44 PM
Just wondering if you have printed out your LAN details after the firmware update:
setup/device settings/LAN settings/Confirm LAN settings/Print LAN details
I’m curious to see if the primary server setting remained the same as your default gateway IP or if they switched it to a local IP address like 0.0.0.1 as mentioned by another user.
if so, I’m not going to bother with the update because my printer has been working fine for the last 3 days. I don’t care about cloud printing.
06-03-2022 10:21 PM
Clear directions would be helpful if you cannot connect with the USB cable. I have a laptop and mobile devices only and no way to connect. I read the directions about needing to connect using an access point mode but it would be helpful if this would be explained further. Thank you.
