09-03-2020 05:42 PM
09-04-2020 10:02 AM - edited 09-04-2020 10:02 AM
B203. Ink carrier calibration issue.
Power the printer off. Open its lid. Power the printer on. The ink carrier should be parked on the right hand side. Once it moves to the middle of its travel, close the lid. This should recalibrate it.
If you continue to receive this error, replacement is your best option, as shipping and repair will exceed the cost of replacement.
09-04-2020 05:21 PM
Thank you for your response. We had the printer off for over 8ish hours and when I turned it on to do as you said it seemed to recalibrate itself on its own. Actually a lot of thinking went on before it fell quiet, so I tested to see if it could print a multi-paged curse schedule from MS Word and it did it with no issue! Do you think the energy saver mode could contribute to the ink carrier issue? I did save it to stay on 24/7 as sometimes I may print from my phone or laptop which isn't nearby so to prevent me from running back and forth I kept it on all the time.
09-05-2020 12:56 AM
The energy saver mode shouldn't affect the printer's ability to calibrate.
If the printer has a timing (encoder) strip, ensure it remains clean.
09-05-2020 05:43 PM
I will thank you for such valuable advice. If these methods don't work, I'll just buy a different printer.
You've been a great help!
01-02-2021 06:21 PM
Thank you for your advice. It worked to remove the Error B203. But the error 203 or 204 will reappear once I start to print. Any further thoguhts?
Thanks,
08-27-2021 03:04 PM
