MG6600 Series Printer Properties Maintenance Tab
Anonymous
Not applicable
My household seems to forget to turn the wireless printer off after using it (it is set to auto start up), so I want to create a Task Scheduler task to do it automatically several times a day.
When you go to Printer Properties after installing the MG6600 driver, you get this nice GUI with a tab called "Maintenance".
Among other functions, you can click a button called "Power Off". Actually it puts the printer in stand-by, but that's fine.
Is there a way to access the function of that "Power Off" button via a command line program?
I wrote an AHK script which works fine when you manually run it, but it doesn't play nice with Task Scheduler. Plus it can't run when the computer is locked.
0 REPLIES 0
