01-15-2017 04:35 PM
The black cartridge (PGBK) won't print corectly though I've adjusted the print heads meticulously. The problem remained even after I changed the cartridge for a new one and both cleaned and deep cleaned it.
Is this a hardware problem which require service or is it something that I can fix myself?
Attaching sheet #1 from the manual print head adjustment routine and a also the Nozzle Check Pattern.
Notice the distorted pattern on the Nozzle Check Pattern.
Manual print head adjustment, page 1:
Nozzle Check Pattern:
05-21-2017 04:02 PM
I have the same problem with my MG7120. Nothing except NOT using the PGBK cartridge has worked (switching paper type to high-resolution paper or matte photo). This is super slow, wasteful, and worse text quality.
Apparently its a printerhead fault that canon is refusing to acknowledge and fix. They say we're supposed to try and get a refund from where we purchased the printer. Yeah right.
