08-21-2015 02:28 PM - edited 08-21-2015 02:29 PM
I VERY rarely print in color. I choose "grey scale" because I do not see a "black only" choice. And yet my printer consumes color cartridges far faster than I would expect using this technique. QUESTION #1 Can I print in "BLACK ONLY" somehow, or QUESTION #2 Am I doing something else wrong? Tks, Phil
08-24-2015 02:22 AM
Hi philr,
Selecting the grayscale option in the printer driver will utilize the large black ink tank in the unit to print the text on the page; however, the other colors in the unit will be used to print the text/items on the page if the following conditions exist:
1. You are performing duplex (two-sided) printing.
2. A paper type other than plain paper is selected in the printer driver.
3. You are printing a document that requires color ink be used.
If any of the above conditions exist, the colors inks will be used to produce the text/items on the page, even if the grayscale option is selected. Also, our printers have a print head cleaning function that is performed automatically as needed to ensure the inkjet nozzles are dispensing the ink correctly. This process uses a small amount of all inks in the printer.
In addition to selecting the grayscale printing option, you can conserve the amount of ink being used by the printer by selecting the FAST print quality setting.
08-29-2015 09:49 AM
Thank you for your explanation of grey scale printing.
Do I take it then, that the answer to my question "IS THERE A BLACK ONLY MODE" is 'no'?
08-29-2015 12:44 PM
Hello.
There is not a specific 'Black Only' mode as you are requesting. To print in black and white, please use the Grayscale option.
