09-30-2019 12:30 PM
Hello, everyone!
I'm having a bit of trouble with our Pixma MG3620. I don't typically print in color, but I *believe* I have in the past. (I owned one of the same printers before, which Canon had to replace after just a few months- it stopped printing altogether. I can't recall whether the last time I printed color was with this one or the previous one.)
Today I went to print out a photo for a frame I picked up, and it came out completely pink-toned. I ran a test print, which also showed only pink in the color lines, while black remained black. I read somewhere that I should ensure that there was no plastic bit blocking the ink from the cartridge, and when I opened it I did not find any plastic whatsoever on the cartridges themselves, but I DID find a big old mess of ink all over the area where the cartridges sit. I tried so soak it up a bit with some Q-tips and run another test print, but it came out the same way.
Where do I go from here?
10-16-2019 12:53 PM
09-30-2019 02:25 PM
Hi kelseysparrow,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
10-16-2019 12:53 PM
