MG2440 Can not Scan
Meliza
When i try to scan i get the following message : Cannot communicate with scanner for these resons: - Scanner is turned off. - USB cableis disconnected.
Please check and try again, Scanner driver wil be closed. Code:2,156,50
But I can Preview the scan ( but do nothing else after the preview) and I can print from the same PC.
Please help, as I have to use the scanner for work.
Thank you,
2 REPLIES 2
Stephen
Moderator
Moderator
Hello Meliza!
Welcome to The Canon Community Forums, and thank you for your post!
We appreciate your participation, however we need to let you know that your product is a model that is not supported by our technical support team here at Canon USA.
The Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click here and select your country or region for your support needs.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Thank you Stephen, I'm From South Africa, will follow your directions.
Keep well
Friends and Family
