MF644CDW - Application Library
GWT
Just set my Image Class MF644Cdw.  Attempting to  configure the home screen on the unit throught the Remote UI.  However, the Application Library link is not longer on the portal page of the UI.  It was there, now it is not.
Why might that be, and how can I get it back?  I want to use the Remote UI to organize the Home Screen buttons.
-GWT
Darius
Whiz
Hi, GWT.
Check the top-right corner of the Remote UI to see if it still lists you as logged in, or if it's timed out.  If you've been timed out, return to the Remote UI main screen using the printer's IP address, and then log back in.  If you are logged in and it still doesn't appear, make sure the account you're using to log into the Remote UI has sufficient administrative privileges to make those changes.
If you need immediate assistance with this issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
1 REPLY 1
Darius
Whiz
Hi, GWT.
Friends and Family
