11-23-2019 03:42 PM
I can print to my MX 920, but I cannot scan to it. When I open my printers and scanners in settings, the only scanner that shows up is my Canon MX870. When I click on add, only the printer shows up. Why can I not scan to this printer?
11-23-2019 04:38 PM
the printer has scanner drivers as well as the printer drivers that need installed. if you have the install cd it is part of the process.
we have a lot of canon install cd's and possibly this one too if you needed to contact us look for Hvytoys on the internet and if you find something about someone who works with printers, you found us.
otherwise, re download your drivers from the internet and then run the install file, plug the printer in when told and you should be okay.
oh, i'd unplug the other printer while doing this, just to make it easeir for you.
11-23-2019 04:40 PM
forgot to mention, if it is a physical problem with the scanner, like it was knocked out of it's track, etc... refer to your service manual for that model printer for instructions on how to fix it. they're pretty easy if you look at one.
11-25-2019 08:29 AM
@imbogus,
I can tell from your post you are using a MAC.
Have you recently updated to 10.15 Catalina?
Either way, visit this page and grab the correct Scanner Specific Driver for your OS
