MF4880dw scanner problem
jertruax
I have a MF4880dw connected wirelessly. I had no issues initially. Now if I attempt top scan a document to my computer the menu pops up with "connect computer". It is connected, it printsjust fine. I reinstalled the drivers and it did not help. Any help would be grestly appreciated. Thanks
3 REPLIES 3
Stephen
Moderator
Moderator
Hi jertruax!
Welcome to the Canon Forums and thank you for your post!
So that the Community can help you better, we will need to know the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks and have a great day!
The computer is running Vista.
Sorry for the short reply, I was using my phone.
Update: I went downstairs to see if it would scan and it did not give me the "connect pc" message. It went through the scan cycle and then had an error. Back upstairs at the computer I had an error message and code 155,0,0.
I was checking out the scanners and cameras from the control panel and saw that it had two different scanners set as default. I deleted the other scanner and it appears to be working now.
I've only had the machine a month and It was working fine before a few days ago. I want both scanners available so I am going to try adding the other one and see what happens.
Friends and Family
