MF4880 printing, (spooler?) problems
NewB4880owner
I have a 2 week old Dell running Windows 8.1 and a 4 day old MF 4880 that I have set up to run wirelessly.
About half the time it worls perfectly, with documents starting to print within a few seconds.
The other half of the time it either has a very long pause, and/or sits and does nothing.  Half of THOSE times it won't allow me to delete pending print jobs either.
I can get it to work again by using the command prompt and clearing the spool, but it has been locking up again relatively quickly.
Any tips or advice?  The drivers came from the install disk; FK4-1353-02.  I was going to see if there were updated drivers but couldn't quite figure out how to do so...
1 REPLY 1
NewB4880owner
Just in case someone else comes across this and is having the same problem, I contacted Canon Support and received a quick and detailed reply that fixed my problem.
The disk that came with the priinter had windows 8 drivers, which needed to be updated to Windows 8.1.  The basic procedure was:
Delete the printers
Delete the drivers, and the toolbox driver
reboot
Install new drivers downloaded from their site
Test everything and do the Happy Dance when it works.
Post video online of the dance so we can all see it
(The last 2 steps are optional)
I would suspect that the complete directions for are available somewhere on the Cannon Support site.
Thanks Cannon for the quick reply, and excellent instructions.
