09-28-2023 05:59 PM
Ran out of ink in black cartridge, loaded new one and won't print
09-28-2023 09:25 PM
Welcome to the forum!
So that the Community can help you better, we will need to know what error message you're getting. Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you
01-14-2025 10:56 AM
Hi same issue here, after loaded the new ink cartridge into TR4527 printer, it keep showing install the ink cartridge correctly, but I already follow instructions to install the cartridge. How we can fix it? Thx
01-22-2025 01:20 PM
Hi Rachel888,
First, it is recommended that genuine Canon ink cartridges are used with your printer.
If you are using Canon ink cartridges, please make sure that the cartridges that you are using are compatible with your printer. The following can be used with your PIXMA TR4527:
PG-243 black
CL-244 color
PG-245 black
CL-246 color
PG-245XL black
CL-246XL color
Ink for your PIXMA TR4527 can be purchased directly from Canon:
https://www.usa.canon.com/shop/ink-paper-toner/finder/pixma-tr4527
