Is the Canon TS8320 not supported on Windows 11 anymore?
Y7DS23
Hi, recently upgraded to a Surface Pro with Windows 11. My old Surface Pro was running Windows 10.
Since the upgrade, I cannot use the TS8320 for scanning. On the Canon website, there are no drivers for Windows 11 which can be installed. Any help or workarounds are appreciated. Thanks
6 REPLIES 6
normadel
Try the Windows 10 driver. In many cases, Win10 drivers, even Win 7 drivers, work in Win 11.
Windows 11 drivers are available for the TS8320
Visit the support portal, select > Downloads > Software and Drivers > Windows > Windows 11
https://www.usa.canon.com/mtest-18/support/p/Printers/PIXMA/TS-Series/3775C002?srsltid=AfmBOooXAeLSN...
None of the drivers are installing. I checked if there is already another driver and there isn't. Never ran into an issue like that before
None of the drivers are installing. I checked if there is already another driver and there isn't. Never ran into an issue like that before.
Is your new Windows 11 Surface Pro based on a Snapdragon ARM processor?
If so, please see this KB article.
https://support.usa.canon.com/kb/s/article/FAQ100604
Thanks for the link. The printer is now detected, unfortunately none of the drivers are installing from Canon that I can install Scan Utility. Printing works now, scanning doesn't. Any tips to fix that? Thanks again for your help.
