Installed TR7520 Software
gggustafson
I recently purchased a TR7520 all in one. As a result, I have about 17 applications for Canon products installed. What MUST I retain? The current list is
Easy-Web Print EX
IJ Network Scanner Selector EX
IJ Network Scanner Selector EX2
IJ Network Tool
IJ Printer Assistant Tool
IJ Scan Utility
Inkjet Printer/Scanner/Fax Extended Survey Program
MX920 series MP Drivers
MX920 series On-screen Manual
MX920 series User Registration
My Image Garden
My Image Garden Design Files
My Printer
Quick Menu
Speed Dial Utility2
TR7500 series MP Drivers
TR7500 series On-screen Manual
I use the printer/scanner over a WiFi network, using the Scan Utility (so I know I need to keep that). Printing is performed through an application's print button. FAXing is not used. I think I can delete
My Image Garden
(I used to have a MX922 that had a printer problem that I replaced with the TR7520) I don't need Image Garden. What else can I uninstall?
Thanks,
Gus
Patrick
Hi gggustafson,
The only item from that list that MUST remain is the "Canon TR7500 series MP Drivers".
If you wish to scan, I would recommend keeping the "IJ Scan Utility" as well.
1 REPLY 1
Patrick
Hi gggustafson,
Friends and Family
