02-26-2015 02:04 PM
I have a Pixma MG2520.
Do I HAVE to replace the color cartridge if it is low or out of one color, in order for the machine to print in just black?
Put another way.
If the color cartridge is empty will the machine print in black only.
Thanks
Sic
03-04-2015 04:52 AM
Hi Sicnarf,
Both ink cartridges will need to be installed in the printer in order to print, even if one of the ink cartridges is low or out of ink. Since your color ink cartridge is out of ink, you can disable the ink level detection function of the printer so that any low/out of ink warnings are not displayed on the printer and then continue to print.
To disable the ink level detection function of the printer, please press and hold down the STOP/RESET or RESUME/CANCEL button on the printer for at least 7 seconds, then release it. Once the low/out of ink cartridge is replaced with a Canon genuine ink cartridge, the ink level detection function of the printer will be re-enabled.
You can also set the printer to print using only the black ink cartridge. To do this, please follow the steps located here.
Hope this helps!
This didn't answer your question or issue? Please call or email us using one of the methods on the Contact Us page for further assistance.
03-13-2016 09:54 PM
How do print only black
05-13-2016 12:39 PM
Do these instructions also apply to the Pixma MG2410?
