IP8720 will not print text
remops
Printer will not print text in test page, pdf and others.It will print the color portion of the test page . It will print JPG files just fine and prints the black. The nozzel check it great. I received this printer from a friend as a gift. Im using win7 USB connection.
I have downloaded from Caon website the drivers installation file.
win-ip8700-1_1-ucd.exe
Any help?
Thanks
1 REPLY 1
Hector
Hello remops,
The ip8720 uses two black ink tanks for printing. The small black is for printing graphics and the large black is for printing text. If you can print images but, text is missing, it usually means the PGBK is missing from the nozzle check print. You can view a sample image of the nozzle check using the link provided HERE. To print documents, you will need the grid marked (A) to appear in the nozzle check.
If the grid is missing, you can try cleaning the print head nozzles using the step provided HERE. After performing a cleaning, you can try another nozzle check using the steps HERE to see if the PGBK grid starts to show up.
If the grid still does not appears, you can try two deep cleanings using the steps provided HERE. You can print a nozzle check between the deep cleanings to see if it works. If it still does not appear, you can try another PGBK ink tank.
If all of those options did not resolve the issue, the printer would need service. The printer has a 1 year warranty and you can create a Canon account using the link HERE, to check your service options
Outside of the 1 year warranty, you can contact our sales department at 1-800-652-2666 to use our Upgrade Program. The Upgrade program will give you a discount and free shipping on a replacement printer.
