04-08-2014 04:33 PM
I have a Canon MX922. I use Ooma with a dedicated # for faxing. I have sent faxes and received faxes but will not send fax to home #s that do not have dedicated fax #. After dialing the persons home phone #, their answering machine picks up and says dial *9 to send fax which I do. I get a fax error report that the line is busy. I have talked to them on cell phones while doing this so I know they are not on their phone or picking up while fax is transmitting. What can I do to correct this problem?
04-23-2014 05:45 PM
Hi tri2sli,
Disabling the error correction mode (ECM) and reducing the transmission speed of the fax may resolve the issue. To do this, please follow the steps located at the links below:
PIXMA MX922 Enable / Disable ECM TX Mode
PIXMA MX922 Reducing Fax TX (Transmission) Speed
Hope this helps!
