01-27-2021 04:17 PM
my PIXMA was bought midyear 2014 and has seen light use with many periods of time (3 or more months) with no use at all. I have tried every cleaning protocol that is built into the machine and still I get blank spaces in printed documents. This is true even when I get good test print results except at the bottom of the sheet where there are just fade outs of the print.
I am wondering if I should just give up and buy a new machine.
04-28-2021 01:46 PM
Hi cliffdscott,
Because the issue still persists, your PIXMA MG7720 would require service. Please note, repairing the printer may cost more than replacing it.
02-17-2021
02:10 PM
04:26 PM
Hi cliffdscott,
Please try cleaning the encdoer/timing strip. To do this, please follow the steps in this article:
https://support.usa.canon.com/infocenter/index?page=content&id=ART163676
If the issue persists, your PIXMA MG7720 would require service. You are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
To help you get up and running quickly, we also offer free standard shipping (if the order is completed by 12:30PM ET). If you would like to take part in this option, please call our Sales Department at (866) 443-8002 weekdays and Saturdays after 11 AM ET (8 AM PT). Let them know you have been working with technical support and the Canon Upgrade Program was offered.
03-23-2021 08:19 PM
Hi Patrick, I tried what you suggested and worked at it diligently and very carefully.
It didn't work. All that happened is no black ink was printed on the test sheet and the colors all showed up as rather weak. I tried two or three deep cleanings and checked all the cartridges to be sure they had ink. I checked the black ones to be sure the part where the ink is distributed to the mechanism that prints was wet, and it was.
So, is it possible that this Pixma and run its course and no longer works without a major repair or replacement is best?
Thanks for your help,
Cliff
04-16-2021 10:46 PM
I am still hoping for a response because I am guessing that when one tries all that you suggest and gets no benefit then it may mean it is time to give up. I am looking for some reassurance that my logic is good and replacing the machine is not a hasty move or an unnecessary waste.
Hope to hear from you still....
Ciff
04-28-2021 01:46 PM
Hi cliffdscott,
04-28-2021 04:22 PM
Thank you Patrick,
I needed confirmation before committing to replacing this old one with a new one.
Be well,
Cliff
