How do I switch the paper feed on the mx892
Rachel
How do I switch the paper feed on the mx892? Thanks
1 REPLY 1
Michael
Hello Rachel.
If you are attempting to change the setting on the printer itself, please perform the following to change the default Plain Paper feed source on the printer:
1.  Press the Setup or Menu Button on the printer.
2.  Use the scroll wheel to select Device Settings and press OK.
3.  Select Plain Paper Feed settings and press OK.
4.  Select your desired feed sources and press OK.
Friends and Family
