12-06-2012 10:52 AM
Hello mikeandsylvia.
The iX6520 has smaller volume ink tanks than the ones that were used in the i9900.
However, you can make adjustments to the settings to reduce the print quality. These adjustments would extend the life of the inks in the unit. Changing the quality setting to 'Fast' will help conserve the amount of ink that is used with your printouts.
11-30-2012 06:31 PM
Have only had this printer for two weeks and although I have been testing its capabilities, the ink levels are dropping by the day. Is it normal for this printer to consume more ink than say the i9900 printer?
12-07-2012 12:32 AM
08-07-2013 11:10 PM
08-08-2013 12:08 AM
OJ,
I appreciate your response.
Like you say, It's a risk investing in foreign Ink Tanks and the quality you will get from them.
I think under the circumstances, I will stick with the OEM cartridges from Canon.
Regards,
mikeandsylvia
