04-14-2013 11:03 AM
04-16-2013 05:10 PM
Hi Mozartman!
The PIXMA MX7600 does not support specifically printing laser labels, but it does support printing US #10 envelopes and European envelopes. What this means is that since Canon does not support printing laser labels, we do not have instructions available to print these. I would suggest checking with the manufacturer of the laser labels you wish to print.
To print envelopes, please perform the following:
Loading Envelopes |
Use either European DL or US Comm. Env. #10-sized envelope.
With proper printer driver settings, the address will be printed according to the direction of envelope.
1 Prepare the envelopes.
Press down on all four corners and edges of the envelopes to flatten them.
If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
If the corner of the envelope flap is folded, flatten it.
If the leading edge of an envelope is puffed up or curled, use a pen to press the envelope flat and sharpen the crease.
Press the envelope flat, working from the middle to the edge.
* The above illustrations show a side view of the leading edge of the envelope.
Important
The envelopes may jam in the machine if they are not flat or the edges are not aligned.
Make sure that no curl or puff exceeds 0.1 inches / 3 mm.
2 Load the envelopes.
(A) Printing orientation
(B) Make sure the flaps are folded.
(1) Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the address side facing UP and the rear flaps DOWN on the left.
Up to 10 envelopes can be loaded at once.
Note
Make sure that the Cover Guide is set upright when you load envelopes in the Rear Tray.
(2) Pinch the Paper Guide and slide it against the left side of the envelope.
Important
Do not slide the Paper Guide too hard. The envelopes may not be fed properly.
3 Specify the settings in the printer driver.
(1) Select Envelope in Media Type. The paper source will be switched to the Rear Tray.
(2) Select the size for envelopes.
In Windows, select DL Env. or Comm. Env. #10 in Page Size.
In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
(3) Select Landscape in Orientation.
Important
Be sure to set the printer driver setting properly. If you do not, the address may be printed in the wrong direction.
