08-01-2020 07:00 PM
I keep getting a 2900 code when I try a manual print head alignment. I noticed that the magenta bars are missing on the printouts. Is this likely to be a problem with the cartridge, or is it something in the printer?
08-07-2020 05:00 PM
Hello.
Check to make sure that the bright orange tape has been removed from the bottom of the ink cartridge. Visit THIS LINK for details about the installation of a new cartridge.
If magenta still does not print correctly, cleanings may have to be done. Visit THIS LINK for information on the normal and deep cleaning procedures.
If there is not improvement with the magenta output, the color cartridge should be replaced.
08-07-2020 05:00 PM
Hello.
08-07-2020 05:53 PM
Thanks. A deep cleaning fixed the magenta problem. The head alignment problem went away after I turned the test print sheet around on the platen. I had it the wrong way initially.
