Getting "Support code 1007" on Canon MG5422 printer when trying to print.
MReynolds81
I have been trying to print some coupons as I've done for years and I have been getting the message "Support Code 1007" on the printer screen and saying the upper cassette is empty. Solution "Load paper". Well duh. But even if I add paper I do not want it to print from the upper tray as I am not printing photos. I am printing coupons so I'm assuming the printer thinks it's printing photos since the coupons have a small picture of the item on each one. Any way to make the lower tray the default for this? I called customer support and the rep wasn't very helpful and said he had the same trouble on his end and then proceeded to tell me "Do some research and see if you can find a solution. Sorry I couldn't help you. Have a nice day!" Some help he was. Anyone know a way around this? Never had a problem with my previous Canon printer which recently died so I bought this one and am beginning to hate it.
51 REPLIES 51
sorry the thread has changed i am using MX925 and trying to print a4 from lower paper tray which i cant unless making doc pdf or emailing and resending
Ametis
I'm moving out of USA already. Can anybody share what to do with this problem? I don't want to have a long distance calls just to solve an annoying problem like this.
Thanks
StaceyHW
I purchased an MX 922 and only used it only a few times.  It ran out of black ink and after I replaced the ink, I am getting a code 1007 when I try to print.  My paper size is correct but it wants to print ourt of the top drawer and I am not printing photos.
Does anyone know what to do?  I see many people have the same problem but I haven't found an answer.
RachelCl
I'm getting the exact same problem since I replaced the ink too. I now can't print at all.
Hi StaceyHW,
The 1007 error caused by:
 1.  There is no paper in the cassette (upper).
 2.  The paper source is incorrect.
 3.  Paper is not loaded properly.
To resolve this, please place paper in the upper cassette, making sure that the small size photo paper such as 4" x 6" (10 x 15 cm) or 5" x 7" (13 x 18 cm), or Hagaki are loaded.
Please note that if you cut plain paper into small size such as 4" x 6" (10 x 15 cm) or 5" x 7" (13 x 18 cm) and try to print on it, the paper jam will occur.
Once the paper is in place, align the paper guides with the both edges of the paper and the press the OK button to dismiss the error.
Next, please make sure that the printer driver is set to the lower tray:
 1.  Click on Start and then Control Panel.
 2.  Click on Printers.
 3.  Right click the PIXMA MX922 and left click on Printing Preferences.
 4.  Click on the Main tab.
 5.  Please set the Media Type to Plain Paper and the Paper Source to Cassette.
 6.  Click Apply and then OK.
Please attempt to print.  If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
Ametis
Hi Patrick
I have the same problem with Stacey.
Problem is, we are NOT printing photos. I was trying to print document from ios phone.
Why it got treated as photos? Even though it is an excel document
Thanks
Hi Ametis,
Are you printing using the Canon PRINT Inkjet/SELPHY app or are you printing using AirPrint?
I am not trying to print photos either, the only way i have resolved this is to email the document to myself and print from my mac. The printer is then happy to print from the lower case. It doesn't even attempt to print from the upper case. Canon this needs to be resolved your end
Ametis
I use airprint mostly. Since I usually print from email attachments.
Same like vonniecox, I usually ended up opening my email from my desktop and print.
But this beats the purpose of having a WiFi printer!
I was trying to print address labels and I kept getting the same error message saying that there was no paper in the upper tray. While was able to resolve the trouble by installing the photo paper properly, I fail to understand why I have to do it at all. Why I couldn't just print out address labels on a regular piece of 8x10 paper from the lower tray is beyond me. I had to make out my own address labels from scratch and waste half my printer paper doing so...ridiculous!
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
