04-22-2024 02:36 AM - edited 04-22-2024 03:31 AM
The print out on the left is from Word, the one on the right is from photoshop.
I have tried adjusting multiple settings in both photoshop and the print settings, and this printer seems to be unable to use actual black ink to print from photoshop/windows Photos/PDF. Any assistance would be appreciated.
Update, tried printing from PDF as well and has the same problem.. The only way to print with actual contrast is if I throw my image in a word document, which is ridiculous and then adds in unremovable margins.
04-22-2024 05:26 PM - edited 04-22-2024 05:28 PM
I just got done with tech support for my G7020. Try this: https://support.usa.canon.com/kb/index?page=content&id=ART177595
Use a flashlight to find that clear strip and look at it from different angles. If there's smudges it can be cleaned gently with a q-tip and rubbing alcohol. I cleaned the front then bent the q-tip so I could carefully clean the back. The strip is pretty flimsy so be careful. Worked perfectly and fixed my ghosting/blurring issue.
04-22-2024 12:45 PM
Similar problems with my G7020, but with printing ghosting/blurred/double vision from webpages, and Word prints fine. No response on my inquiry at this point yet. I reinstalled the latest driver, firmware, cleaned the print heads, aligned them, etc etc. It has to be some kind of software issue.
