G4210 Print Skewed On Certain Lines
silveraz
I have a four year old G4210 that consistently skews print on the same few lines. For example when printing a Windows Printer Test Page the same few lines are skewed every time.  The nozzle check looks fine. I have done cleaning, deep cleaning, the print head alignment procedure and also cleaned the encoder tape but nothing has helped or changed the symptoms. The print is readable for the most part but when printing a return label with a bar code - the bar code was not readable on the shipper's scanner.  Time for a new printer or have I missed something?
Thanks in advance for suggestions / advice.
0 REPLIES 0
