11-15-2017 02:22 PM
My canon g3000 doesn't print black, already cleaned and the problem persists. Colors work fine and the tank is more than half way full.
11-15-2017 05:58 PM
10-11-2021 10:49 AM
I hve run the printer head cleaner threetimes and although the black ink has been filled, it still won't print. It ALSO won't print the nozzle check pattern. There is paper inthe machine and I have run the diagnostics as the msanual says. I can hear it cleaning but nothing gets printed.
10-11-2021 10:50 AM
I followed the solution and the print nozzle check pattern did not print.
04-22-2019 02:29 AM - last edited on 04-22-2019 08:17 AM by Porcha
i have done the same thing i turned of the printer and then i tuned on the printer and I hold the stop button until warning alaram flashes now black color is printing when i test it for nozzle pattern but when i give a webpage call (Removed link as per Forum Guidelines) home page for checking all colors i am getting white lines like gap now what should i do i need to clean the header or i need to follow the same procedure of using stop button but lot of my ink is wasting.how to fix it please help me
04-25-2019 08:06 AM
Hello smitha0030,
I understand that you are continuing to have some printing issues with your PIXMA G3000 series Printer. Performing two cleanings may resolve this issue. The following steps will assist you in performing the cleaning process:
Now that the cleaning process has been completed, please print the nozzle check pattern. The following steps will assist you:
12-15-2019 07:45 AM
I ALSO HAVE THIS PROBLEM - IS IT A COMMON PROBLEM WITH THE Q3000?
I HAVE TRIED DEEP CLEANING MULTIPE TIMES BUT IT WILL STILL WILL NOT PRINT IN BLACK.
THE PRINTER IS LESS THAN YEAR OLD AND I HAVE ONLY USED HALF OF ONE BOTTLE OF INK.
I SUSPECT THAT THE NOZZLES ARE BLOCKED BUT CANNOT FIND HOW TO RESOLVE THE PROBLEM.
OS ANYBODY ABLE TO OFFER ADVISE?
12-15-2019 08:20 AM
Hello, ALANFISCHER,
Per the Community Guidelines found HERE, please do not post in ALL CAPS. We reserve the right to remove posts that are in all caps, due to them being percieved as yelling.
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market. Canon USA does not sell or support a model Q3000.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
12-15-2019 06:57 PM
12-07-2020 05:03 PM
ai contacted Canon with the same problem and, as I was out of warranty, they sold me a new black print head for $59Cdn. My black problem is resolved, but now I have no colored ink flowing to the color print head. Canon's answer to this was that I should probably buy a new printer $240 Cdn) as it would probably be cheaper than sending it in for repair! I see they now have a new G3260 printer with a different ink number.
12-07-2020 07:25 PM
Hi Kiwi5715, I also ended up buying a new printer and have had no further problems.
03-05-2020 07:31 AM
Mine stopped printing in black, but printed fine in all the colors (same ink levels). After I ran deep clean, it prints in black, but not in magenta. Another deep clean of just the color toners didn't do anything. Help?
