11-15-2017 02:22 PM
My canon g3000 doesn't print black, already cleaned and the problem persists. Colors work fine and the tank is more than half way full.
10-11-2021 10:50 AM
I followed the solution and the print nozzle check pattern did not print.
06-03-2023 11:47 AM
I had the same issue. Got it working again and now the magenta won't print. All tanks are nearly full, and I just did a regular cleaning, deep cleaning, and system cleaning to get the black to print. Maybe these Canon G3000 series are lemons.
06-03-2023 09:01 PM
I think you’re right kidbonita - I eventually solved the problem by buying Hewlett-Packard! Never had a problem since I changed.
