02-22-2018 07:24 AM - edited 02-22-2018 10:29 AM
Cannon MX920
I recently ran out of paper and it was a few days before I had a chance to buy some more so when I did, I reloaded the cassestte with paper and put it back into the printer and tried to print something when I get the error telling me there is no paper in the printer.
I never had this issue before, This only occured once I ran out of paper and No I didn't try and print anything when I knew the paper tray was empty.
I know that the printer is working fine and there are no jams and that the printer is able to feed the paper because when I tried to make a copy of something It gave me the out of paper error but I restarted the printer and tried again and this time it copied the paper with no issue and printed it so to make sure it was indeed working again I tried to make another copy and sure enough I got that error again so I decied to see what would happen if I restarted the printer and did what I did last time and sure enough as soon as I restarted it and it made the copy with no issue.
So I then went to my computer to try and print out something and it's giving me the "No Paper" error again.
05-02-2018 09:37 PM
Nope, I actually went and bought a new printer but had to take it back because it was defective so when I got back home I decided to play with it some more and now all the sudden it's printing without any issues.
I did delete the printer and reinstall it on my PC with the drivers from canon website but don't know if that actually made a difference or not
05-12-2018 02:32 PM
Check that the paper type is not set for 4x6 for photos which is the default. I transferred the pic to a word doc where the default was A4 and no more error message saying that the printer is out of paper.
12-09-2018 11:21 AM
Where do you chage paper type?
08-11-2019 07:58 PM
Dont throw your printer away just yet! I had the same problem with my 490 pixma and after reading volumns and watching umteen videos I decided that the paper take-up wheels were dirty and this turned to be true. The fix? A low tech solution: I took a long chop stick and attached a Q-tip to the end with rubber bands it then swabbed the roller wheels with isopropyl alcohol on the Q-tip. Viola! Problem solved! Printer works like new again!!
Hope this helps someone else! It made my day! 🙂
Cheers,
MK
10-25-2020 01:22 PM
05-17-2021 11:08 AM
I had a similar problem with a MF741Cdw. The solution to the problem was simply to use the newest and correct print driver. Windows automatically loaded 'MF741C/743'. I downloaded 'Canon FF741C/743/C UFR II' from the Canon website, but I assumed the newer print driver would overwrite the older one, and I did not notice the difference in the name. I had called Tech Support (50 minutes on hold), but the person I talked with was unaware of the new driver and the different name.
