08-17-2023 12:15 PM
Attempting to install August 2023 driver update. Closed all apps and disconnected printer, as per directions. Selected USB cable as connection method. Connected printed and waited for detection. "Printer not detected." Tried different cable, different USB port (even though printer had been working fine with both original). No change. Windows 10 22H2 19045.3324.
08-22-2023 01:47 PM
Go into device manager and scroll down to universal serial bus controllers. Click the arrow and when the menu expands, check to see if the printer is detected or if a generic printer device is detected.
If the printer is detected, there may be a security feature blocking the computer and printer from communicating correctly.
If the printer still wont add after adjust security settings and installing again, I recommend reaching out to Canon support. The real time feedback of a live technical support call/chat would be very beneficial in this case.
You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
08-22-2023 01:47 PM
09-13-2023 02:31 PM
Thanks for your information -- sorry to be so long in saying so, but I've been away for a while. Anyway, in Device Manager, under USB there are two instances of "USB Printing Support". However, under Printers, above, "Canon MX920 series Printer" is there.
