12-20-2016 08:12 AM
To scan a file, I right-click on the Canon MG2500 icon and select Start Scan. In the window that appears, "Preview or scan images as separate files" is ticked by default. How can I change the default so that it is never ticked?
My images always scan as JPGs. Is it possible to have them scan as PDFs? I thought I could achieve this by selecting Documents under Profile, but the following error appears when I try that: "Failed to initialize selected paper source."
01-16-2017 11:56 AM
Hi jmt356,
If you would like to save a scan as PDF, please use the "Document" button on the IJ Scan Utiltiy. This button is set to save as PDF by default.
For more information, please use the appropriate link below:
(Windows) http://tinyurl.com/jng3nhz
(Mac OS X) http://tinyurl.com/jg8nz3x
07-12-2020 03:20 PM
I have Windows 8.1 so would you please provide a step by step to change scan options to pdf rather than the jpeg and other options in the default settings? I attempted to follow your directions for Windows 10 but I wasn't comfortable with what I was navigating in.
This is for the TS8320 I just purchased and set up.
Thank you much.
wayno
