CanonPixma 922
SGlinick
This unit worked fine with my Netgear router. But after installing EERO it no longer works wirelessly or via an ethernet cable. My understanding is that EERO uses WPA-2 encryption. Is the problem that the Canon PIXMA 922 will not support this? In that case do I need to buy a new unit?
1 REPLY 1
Hector
Hi SGlinick,
The MX922 can work with WPA-2 so it should be compatible. If you have a new router, the printer would need to be connected to your new network to continue working. You can connect the printer to your network using the steps in the link HERE. Since you are using an EERO router, you can select the option for multiple access points if it comes up.
