10-04-2015 05:41 PM
Hi!Newby here!I want to print some labels and in order to make a test o a normal paper first i have print the format of the labels and after that i had try to print some squares inside the labels to see if they will match.The results are quite weird because as you can see from the pictures.(in the software the squares had the same center)
I had run the alignment setting for the printer (manual and automatic) and i had run the cleaning of the nozles and rolers. Nothing helps.
Please advice!
Thank you!
