12-04-2012 03:47 PM
I have a Canon Pixma MX340 multi-function printer. How do I clear Error 5200? The message said to turn the printer off and then on, and if that did not clear the error to consult the user's manual. On/off did not clear the error, and the online user's manual does not have Error 5200.
09-11-2017 11:07 AM
AWESOME! Thank you cx2browns for the FIX. I was about through with Canon and was getting ready to go out also and buy another printer. You have saved me $$$$! You just don't know how fustrated I was with this printer. Not able to use it for a couple of months. I appreciate you sharing with us the solution. Again, thank you, thank you and thank you. smoquay@aol.com
09-12-2017 07:58 AM
It worked, as nothing else did! Thanks for sharing your solution.
06-24-2013 07:32 AM
Read cx2brown's fix.....it worked perfectly for me....
07-18-2013 06:56 PM
Thank you this worked follow the steps by resetting, thanks you saved me from buying another one.
11-19-2013 09:29 AM
I have the fix saved on my favorites, have used it several times since discovering the answer on this site.
Thjank you
@PaulR wrote:I have a Canon Pixma MX340 multi-function printer. How do I clear Error 5200? The message said to turn the printer off and then on, and if that did not clear the error to consult the user's manual. On/off did not clear the error, and the online user's manual does not have Error 5200.
11-26-2013 11:24 AM
Replacing both ink cartridges worked for me. Also have a look on Secrets of error5200 on Canon printers
02-07-2014 04:16 PM
03-05-2014 06:27 PM
http://www.youtube.com/watch?v=4obGfxsqMIo
This video will help you, even though it is in russian.
All Canon wants is for you to buy a new printer. This works!
05-08-2015 09:57 PM
Recommendations on this site did not work for me, i.e., power off, hold stop, etc.
Canon manual does not mention 5200, but elsewhere in printer ink forums, I found the answer. If you are using after-market cartridges, the printer apparently believes the black cartridge is empty and tries to make black ink from the other colors, thus exhausting one or more of the colors in the 211 cartridge. Replacing or refilling the 211 caused me to stop getting the Error 5200.
You will get a warning about printing with low ink. Ignore it and print.
08-12-2015 12:41 AM
