12-04-2012 03:47 PM
I have a Canon Pixma MX340 multi-function printer. How do I clear Error 5200? The message said to turn the printer off and then on, and if that did not clear the error to consult the user's manual. On/off did not clear the error, and the online user's manual does not have Error 5200.
05-09-2017 10:35 PM
YES! Those multi-step instructions on fixing the printer worked! Thanks! I'm am technologically challenged, yet I figured it out.
06-08-2017 04:17 AM
08-31-2017 06:22 PM
I have a Canon MX350 printer. Cannot get rid of Error 5200.
Have tried the suggestions already posted with out sucess
09-11-2017 11:07 AM
AWESOME! Thank you cx2browns for the FIX. I was about through with Canon and was getting ready to go out also and buy another printer. You have saved me $$$$! You just don't know how fustrated I was with this printer. Not able to use it for a couple of months. I appreciate you sharing with us the solution. Again, thank you, thank you and thank you. smoquay@aol.com
09-12-2017 07:58 AM
It worked, as nothing else did! Thanks for sharing your solution.
01-05-2018 04:38 PM
01-05-2018 04:47 PM
01-05-2018 06:13 PM
04-30-2018 11:52 PM
1: Switch off printer
2: Press and hold STOP button for 2-3 secs
3: Press and hold ON button, and release the STOP button
4: While still holding ON button, press teh STOP button 5 times.
5: Now release all buttons
6: LCD screen will turn on and will be blank.
7: Give it a minute and turn the printer off, and then back on.
08-05-2018 11:49 AM - edited 08-05-2018 11:50 AM
Brilliant .
Thanx so much. Worked. !!!
I couldn't find the original post either. I printed this out just in case.
Pip
